Adhesives, Fluids, Lubricants, and Sealers
Status
Not open for further replies.
ripmf666
Registered user
Kansas City Mo
Service Information
<FORM onsubmit="JavaScript: return true;" method=post name=CellHandlerForm action=/si/cellHandler.do>
Document ID: 1651794 <HR>
<TABLE border=1 width="95%"><TBODY><TR><TH vAlign=bottom rowSpan=2 align=middle>Application
</TH><TH vAlign=bottom rowSpan=2 align=middle>Type of Material
</TH><TH vAlign=bottom colSpan=2 align=middle>GM Part Number
</TH></TR><TR><TH vAlign=bottom align=middle>United States
</TH><TH vAlign=bottom align=middle>Canada
</TH></TR><TR><TD vAlign=center align=left>Sealing Cup Plug
</TD><TD vAlign=center align=middle>Locktite 272T or Equivalent
</TD><TD vAlign=center align=middle>12345493
</TD><TD vAlign=center align=middle>10953488
</TD></TR><TR><TD vAlign=center align=left>Upper Oil Pan to Cylinder Block
</TD><TD vAlign=center align=middle>Sealant
</TD><TD vAlign=center align=middle>12378521
</TD><TD vAlign=center align=middle>88901148
</TD></TR><TR><TD vAlign=center align=left>Flywheel Housing to Cylinder Block
</TD></TR><TR><TD vAlign=center align=left>Engine Front Cover to Cylinder Block
</TD></TR><TR><TD vAlign=center align=left>Lower Oil Pan to Upper Oil Pan
</TD></TR><TR><TD vAlign=center>Crankshaft Bearing Side Cap Bolts
</TD><TD vAlign=center align=middle>12346004
</TD><TD vAlign=center align=middle>10953480
</TD></TR><TR><TD vAlign=center align=left>Intake Manifold to Cylinder Head
</TD></TR><TR><TD vAlign=center align=left>Camshaft Bearing
</TD><TD vAlign=center align=middle>Engine Oil
</TD><TD vAlign=center align=middle>12345634
</TD><TD vAlign=center align=middle>993297
</TD></TR><TR><TD vAlign=center align=left>Rocker Arm Shaft
</TD></TR><TR><TD vAlign=center align=left>Valve Bridge Cap
</TD></TR><TR><TD vAlign=center align=left>Valve Stem Seal
</TD></TR><TR><TD vAlign=center align=left>Valve Lifter
</TD></TR><TR><TD vAlign=center align=left>Piston Ring
</TD></TR><TR><TD vAlign=center align=left>Crankshaft Bearing
</TD></TR><TR><TD vAlign=center align=left>Connecting Rod Bearing
</TD></TR><TR><TD vAlign=center align=left>Thrust Bearing
</TD></TR><TR><TD vAlign=center align=left>Connecting Rod Small End Bushing
</TD></TR><TR><TD vAlign=center align=left>Push Rod
</TD></TR><TR><TD vAlign=center align=left>Crankshaft Bearing Cap Bolt
</TD><TD vAlign=center align=middle>Molybdenum Disulfide
</TD><TD vAlign=center align=middle>1052948
</TD><TD vAlign=center align=middle>992926
</TD></TR><TR><TD vAlign=center>Lithium Grease
</TD><TD vAlign=center align=middle>Lubricant
</TD><TD vAlign=center align=middle>12346293
</TD><TD vAlign=center align=middle>--
</TD></TR><TR><TD vAlign=center>Parts Cleaner
</TD><TD vAlign=center align=middle>Cleaner
</TD><TD vAlign=center align=middle>12377981
</TD><TD vAlign=center align=middle>10953463
</TD></TR></TBODY></TABLE>
© 2010 General Motors. All rights reserved.
</FORM>
Status
