adding to fuse block
chevyCowboy
Springfield Nebraska
there seems to be quite a few open slots in both the underhood fuse block and the in cab fuse block. is it possible to add to them to keep things neat.
For example in the UHFB there is a spot labled for heated mirrors (i have added heated mirrors and a timed relay set up, in a differnt thread) i still need to get power for this set up and i would like to just use the stock fuse block. In the spot for mirror heat there is all ready power (to one side of the fuse) but there are no contats for the other side, any one know where to source them?
I added a second fuse block in my truck. I installed it under the cup holder in my center console. I still need to add all the extras to it.
jy= junk yard?
Yes you can add to the original FB. We do it all the time. Makes for a professional/clean install.
FB=Fuse box:hihi:
where do you get the terminals to add to them? do you add to the ICFB how do you get it out to work on it dosent seem to be a lot of slack in the wires
Yes crimp on. Cut the wire back 6" or so then depin it from JY box. Then soldier to new wire/s.
