AC Oil filter
It will fit has the same thread.
The wix website lists its equivalent as being a High Performance/High Pressure version of the standard 51060 that wix supplies for these engines.
What is of interest is that the wix PF35A equivalent has a micron rating of 32 as opposed to the standard 21 micron. Now these are wix stats and the AC Delco may well be different but just an FYI that you may possibly be using then a slightly coarser filter.
Cheers
Nobby
Thank's for the reply Nobby ,the filter is actually a Donaldson P550964 it cross's to the AC filter I thought it would be easier asking about the AC #.
Mark
Well funnily enough the Donaldson crosses to the standard wix 51060.
Donaldson specs the micron on that one is 35 on the P550964.
Cheers
Nobby
Thank's Nobby maybe I'll just forget about using the Donaldson filter then. Our 6.5's don't need any extra help or encouragement on self distructing.
Mark
