Big T
After replacing the front bearings last fall, the ABS was working nicely.  That is until the wires on the Left Front sensor rubbed through.  I tried splicing them and only periodically did the ABS work.  I ordered a new AC Delco Sensor from RA and it took a few months to get around to putting it in.  I sense that there was pent up fear from the bearing replacement job where the bearing hub bolts were darn near impossible to get out.  Not this time.  I had the hub off in minutes, replaced the sensor and reinstalled.  Unfortunately, the ABS light is still on.  I checked the ABS fuse in the engine compartment and that's fine.  As recently as a couple weeks ago the ABS was working sporadically with the spliced sensor in place (hard to get a good splice on it).
What am I missing? Should I be checking for frayed sensor wire on the right side? Is there any test that I can do?
