in case others come here for info related to abs sensors,, here's more of what I've found, for 95 OBD1
I pulled codes on mine,, I got 21 22 23 25. The light has been on for almost the whole time I've had the truck. the Zone has new ones for 35 ea,,, and I'm doing rotors, new loaded Napa calipers so I thought I'd just throw the sensors in. I seem to remember it working one time, and it took me by surprise. If I dont' like it,, I'll just pull the ABS fuse,,, no light no worries.
what I was wondering,,, is are these soft codes,, that will go away when fixed,,, or how would you clear the abs codes?
Pulling Chevy Truck OBDI Brake Codes Information
Here's information on pulling
Chevy Truck OBDI Brakes codes for the RWAL and AWAL brake systems and codes.
PROCEDURE:
Diagnostic Trouble Codes (DTC) 's can be displayed by jumping terminals "A" and "H" of the
Data Link Connector and observing the flashing of the "BRAKE" warning light. This should only be done when the
brake lamp is "ON".
The terminals must be jumped for about 20 seconds before the code will begin to flash. Count the number of short flashes starting from the
longflash. Include the long flash as a count. Sometimes the first count sequence will be short. However, subsequent flashes will be accurate. If there is more than one failure, only the first recognized code will be retained and flashed.
NOTES:
DTC's 6, 9 and 10 will only turn the "BRAKE" lamp on while the fault exists. These are soft codes faults and can only be read with the Tech 1 scan tool.
Do not jump terminals "A" to "H" if the "BRAKE" lamp is not on. Jumping the terminals with the "BRAKE" lamp off will set a false DTC 9. This will turn the "BRAKE" lamp on and disable the antilock system.
- 1, 11, & 12 ECU Malfunction
- 2 Open Isolation Valve or Malfunctioning ECU
- 3 Open Dump Valve or ECU Malfunction
- 4 Grounded Antilock Valve Reset Switch
- 5 Eccessive Actuations of the Dump Valve
- 7 Shorted Isolation Valve or Faulty ECU
- 8 Shorted Dump Valve or Faulty ECU
- 9 Open Circuit to Speed Signal
- 13, 14 and 15 ECU Malfunction
The following is a list of the OBD-I trouble codes for the four wheel
anti-lock brake system.
*Code 21:
right front speed sensor or circuit open
*Code 22: missing right front speed signal
*Code 23: erratic right front speed signal
*Code 25: left
*Code 26: missing left front speed signal
*Code 27: erratic left front speed signal
*Code 29: simultaneous drop-out of
front speed sensors
*Code 35:
vehicle speed sensor or open circuit
*Code 36: missing vehicle speed sensor signal
*Code 37: erratic vehicle speed sensor signal
*Code 38: wheel speed error
*Codes 41 through 54: control valves
*Codes 61 through 63: reset switches
*Code 65 and 66: open or shorted pump motor relay
*Code 67: open motor circuit or shorted BPMV output
*Code 68: locked motor or shorted motor circuit
*Codes 71 through 74: memory errors
*Code 81: brake switch circuit shorted or open
*Code 86: shorted anti-lock indicator lamp
*Code 87: shorted brake
warning lamp
