I thought 93 was the first year of 134a on these trucks?
1994 was 1st R134A in C/K pickups factory. 1993 was R-12. GM did not change much from the R-12 design and the 'factory' 134a systems more or less sucked with 134a from the factory. 1993 should have had the barrier hoses that worked with R134a, yet the o-rings are wrong.
GM attempted some patches later like a electric pusher fan, bigger dash vents, and larger condenser. Only when they went with the driver side mount different design compressor did you get good cold air from the C/K pickups.
It wasn't until you added a better fan and a VOV that the performance came close to R-12 on the factory retrofitted systems. And that would not fix the undersized system that was marginal at best with R-12 in a Yukon w/o rear air. 134a and you were miserable in the rear seat and warm in the front.
The best patch was a lower turn on fan clutch like a hayden and an electric pusher fan wired to the AC clutch. More fan blades on the clutch fan would have helped too.
Before the VOV orface tube I have regretted using 134a in these systems esp. in the hot climate I live in. Disappointed in my 1st AC shop performed R134a conversion on a 93 c/k v6 PU and fought the a Yukon system forever. The idle temps of the VOV make these systems tolerable again. The pusher fan helped but the colder air after startup was found to occur with a hayden vs GM fan clutch. The GM clutch did not kick in soon enough causing a 15 min wait for the coldest air. Not fun in 115 weather.
The bottom line is R134a needs more airflow across the condenser than R-12 to keep you cool. No not same outlet temp degrees: keep you from breaking out into a sweat with the AC on high when it is over 100 degrees out. 110 out and AC gives up, 120 degrees and it takes a major mod to keep it cool because factory setup will not.
Edit to answer the other compressor question:
The newer driver's side mounted compressors are variable displacement and run all the time. Thinking you would change the belt drive brackets and climate control head and maybe the body computer to get that system to work as designed. Not worth the headache vs. a VOV and pusher fan added on to our old system.
