ak diesel driver
6.5 driver
what's the best way to check for slop in them?
What did it cost you in parts? I am thinking of doing similar.
| Part Type | Brand | Part Number | cost | QTY |
| Lower Ball Joint | Moog | K6291 | 54.99 | 2 |
| Upper Ball Joint | Moog | K6344 | 49.99 | 2 |
| Front Sway Bar Bushing | Moog | K6453 | 18.99 | 1 |
| Sway Bar Link | Moog | K80631 | 30.99 | 2 |
| Outer Tie Rod End | Moog | ES2836RL | 54.99 | 2 |
| Inner Tie Rod End | Moog | ES2838RL | 55.99 | 2 |
| Tie Rod Adjusting Sleeve | Moog | ES2004S | 16.99 | 2 |
| Center link | Moog | DS1408 | 67.99 | 1 |
| Idler Arm | Moog | K6447 | 89.99 | 1 |
| Idler Arm Bracket | Moog | PK6722 | 96.99 | 1 |
| Pitman Arm | Moog | K6335 | 60.99 | 1 |
| Steering Gearbox | Cardone | 27-7539 | 219.99 | 1 |
| Steering damper | Moog | SSD56 | 61.99 | 1 |
| Front Shocks | Rancho | RS5150 | 57.99 | 2 |
| Rear Shocks | Rancho | RS5190 | 57.99 | 2 |
| CV Axle | MasterPro | GM8002 | 69.99 | 2 |
| Total | $1516.75 |
