Silverado6.5td
Diesel Powered Chevy
I have a 4l80e trani in my truck and recently started having problems with the OD. After the trani starts to warm up (around 150 degrees) I lose OD and it starts to shift hard from 1-2 and 2-3. When it cools down I get it back. It is starting to do this now even before the temperature starts to move the needle. The only code it has ever thrown is a P1870 (transmission component slipping).
I had it in to a trani shop and they told me that it could possibly be the speed sensor if it is still the original one, but that it has most likely been changes sice there is 325,000kms on the truck. If that is not the problem that it needs to be rebuilt. When he took it for a test drive prior to losing OD, he sais that the torque converter wasn't locking up.
So after reading up on many posts, I came to the conclusion to change solenoids A and B as well as the PCS and TCC solenoids as a starting point.
Then I read on a trani website that the torque converter clutch regulator valve can also be responsible for throwing the P1870 code.
I called another trani shop in the area asking for the TCC regulator valve kit and it is $50. He asked me what the trani was doing, so after I explained it to him, he told me that the valve kit I asked for and another valve in the valve body should be changed with the upgraded kits he has.
It is $120 for both kits, one requires tools to bore out the hole. He said he would install them for me for free.
I asked him if I should be changing the other solenoids as well while I have it apart especiallt the TCC solenoid and he said the if solenoids A or B were defective it would throuw a code for that and I would only have specific gears depending on what solenoid is defective, but since 1,2 and 3 still work fine when OD is lost those solenoids should be fine.
He also said the TCC solenoid should be fine as well, but he would do a resistance test on it to see.
I value everyone's opinion and this place has been an excellent place to learn about diesels and related problems, so I am hoping you guys can provide some feedback as to what you might think is the problem or what I should be trying/changing.
It is difficult sometimes to trust repair shops or dealers as they try to just milk you for every penny than can squeeze from you or try and do work that doesn't need to be done, but this shop seems to be genuine in their intentions, as I opened the door for them to sell me extra parts and they told me I didn't need to change those solenoids, and they are going to install the 2 valve kits that they believe is the problem for free. Those parts are comparable in price if not a little cheaper to parts in the US if I had them shipped up here with the exchange rate and any customs and border fees, so they don't seem to be trying to gouge me in that area either.
Has anyone had similar problems with their 4l80e trani and if so, what did you need to do to fix it.
Sorry for the long post and I appreciate all the feedback.
Rob
Rob
