Quick spool- or anypart of the turbo affecting mileage: the more air flow (not just boost) and the sooner you can add it as well as keep it all the way up the rpm band, the more it helps create power. The more power you have available at lower throttle position you can move the truck wigh less fuel down the road. The hard part is not "enjoying" the new found power too often. So instead of towing a trailer up the hiway at 90% throttle, you can do it at 50%. Instead of W.O.T. Getting up to speed from a stop light, its only 50% throttle. That helps mpg a lot.
@6.5L I think we all have a list for Leroy, Most of us just can't get the bank account to back it. I know thats my problem. Haha
I really enjoy seeing the different turbos you run and posting the details.
I'm kinda surprised i havent seen you guys jump into compound turbos with a waste gate dumping from the little gm into the ATT or something big like that. More expense, but already having the factory as the small, and upgrading to the bigger one, then later when the playing starts it is just plumbing, a wastegate, and an extra boost gauge for testing.
For me just fitting the hx40 or ATT is a challenge, but to add both would be hard. Knowing how they do on a friends 7.3 and a big pump has made me consider turbo on the roof, no joke. I just can't pull that trigger...
So something to learn by the newbys here is when upgrading turbos, if you know you will not tinker with your rig for fun or getting the most out of it, sell the old parts to offset the new ones. But if you ever get to playing around with stuff, shelf the old turbos for later projects and parts trades.
