fbh31118
Cadet
My friend has a 98 2500 with a 6.5td. He does a lot of towing with it and will be going to a one ton set of leafs in the rear. We plan on building a set of brackets for the overloads if we can't find a donor truck to get these bracket from. His question is 'what is the clearance between the over load leaf and the bracket that it contacts on the side of the frame', when the truck is unloaded? Also, is there an equal amount of 'air gap' between the bracket and spring from the front to the rear?
Just to be clear; I'm referring to the spring set that would be bolted to the top of the main spring set and contacts a set of brackets bolted to the frame.
Thanks in advance for any help!
