I believe it was, the 506 and some of the 141 blocks had the squirters.How did the '96 engines rate? Was that the first year of the oil squirters?
When they did the oil squirter blocks, they failed easier because of the cracking that occurs, but I never saw or even heard of one go in under 150,000 miles. Why is that crucial? Because back then almost no one knew they biggest issue was the harmonic balancer failure. When the rubber in the hb fails, it allows movement of the counter weight, which instead of helping the crank amplifies it's vibration. This vibration is held in place by the main caps which transfer the load to the block right through the oil squirters. When the balancer is taken care of, the crank and block has a long life.
Many people saw the amount of cracked 506 blocks vs the 141 blocks spoken about online and pin the 506 as bad. I think it was a pure numbers game. The fleet numbers, not just mine but several fleet mgrs. used to share info, saw same results from 506 as 141. imo until the optimizer, I don't value one block above another.
The goal was sell the 99.but if you are thinking of moving that negates the whole reason to shop for older.
