Okay I'll try that. ThanxI would think you have air getting into the fuel system. replace your return line on the IP which is a 1/4" hose about 6" in length located right in the front of the IP up top. replace it with some clear tubing you can get at most any hardware store. id does not need to be fuel rated, run the engine and see if you don't see air bubbles fuel flowing.
Where should I go to buy a lift pump? Prices r all over the place for ac delco. ThanxWhen I'm underload, it's sputters. This morning it didn't sputter but I noticed black smoke coming out when i'm going up the hell or i'm underload. New IP new PDM. New ops, New fuel tank, fuel filter, grounds. Any help would be appreciated
the bubble fare I mentioned is simply to give something for the rubber fuel hose grip when you slip it over the line and clamp it. this way it won't push off the steel line under pressure. the LP should only be pushing 8-14 PSI up to the IP.. the steel lines from the IP to the each of the injectors will reach up over 2000 psi. so use safety there!I have a flaring tool so I might do the filter anyway. Never k ow what's in the deisel. I changed full filter and that deisel was exactly the same color as the new fuel I put in my can.
Yup, but that's only on the short steel lines coming off the IP going to each injector. that's low pressure compared to the newer diesels that produce upwards around 20k to 30k PSI !Wow! 2000psi.
