I'm new to the GM Diesel arena, although pretty familiar with drivetrain overhaul & repair in anything powered with gasoline. Just picked up a 94 GMC C3500 Dually. It has the "F" 6.5 liter, Turbo Diesel Engine. A little history, from the previous owner. This truck started smoking badly after being overheated. The truck was then parked, and left sitting for 3 years, with nearly a full tank of fuel. Fast forward, the oil level in the crankcase was above the mark by about a gallon, and was the consistency of pudding! :rolleyes5: The Coolant level was down nearly 2 gallons as well. Suspecting at minimum, a blown head gasket. I purchased a Chilton Manuel and started reading through these forums, before tearing it apart. Here is the requested info sheet (a great idea BTW)
Problem: Explain your problem in concise language (ie: Cranks but won’t fire). _________After replacing cylinder heads, injectors, glow plugs, filters, & fluids. Will running the engine with 3 year old diesel cause excessive exhaust smoke? Will cetane boost help this issue? or a different additive? or does the fuel need to be drained and fresh fuel added?
- Year: ___1994___
- Truck model and class (ie: c2500) ____C3500_____
- Automatic or Standard _____Auto_____
- Mileage: (indicate miles or km) ____166,168_____
- Replaced parts and mods (IP, PMD, chip/PCM, TM, injectors etc) ______heads, injectors, glow plugs, remote PMD added, fluids, T-stat_____
- Model: ‘S’ or ‘F’ engine, NA or Turbo, EGR? ______Turbo, non-egr________
- Ambient outside temp: (indicate *C or *F) _____50 degrees F._____
- What fuel are you using? (#1 Diesel, #2 Diesel, Bio, VO, WVO, etc) ____old #1 Diesel?_____
- What fuel additives are you using? _____none______
- Where are you located? _____Sacramento, CA________
- Air filter ____new_____
- Fuel filter ____new_____
- CDR Valve? _________
- Coolant – last flushed/replaced at ______new_______
- Oil – synthetic/regular, changed at _____new, rotella 15-40______
- Batteries – state of charge, (matched set) replaced at ______new, matched_______
- Battery cables and grounds (removed, cleaned and tightened): ______cleaned & tight________
- Glow Plugs - how many miles on them? ____new_____ What type? ______AC 60g_______
- Injectors - last changed at _______________
- What were you doing when it happened? ______unknown________
- How was the truck running fine before this problem appeared? _______unknown______
- Has this problem ever happened before? _________unknown______________
- Describe any related factors that might be part of the problem. _______unknown_______
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) __Y__ And? ___no DTC's stored_____
Diagnostics:
1] Starting:
1a] Does the engine start? ____Y_____
1b] Does the engine crank over? ____Y____
1c] Are your batteries fully charged? ____Y_____
1d] Have you removed, cleaned, and tightened all battery connections? ___Y_____
1e] Does your Wait to Start light come on for a time? How long? _________
1f] Does your glow plug light come on? ____Y_____ For how long? ____10 seconds (cold)_____
1g] Do you see smoke from the exhaust while cranking? What color? ____N____
1h] Does the Service Engine Light Glow during Start/bulb check? ___Y_____
2a] Can you hear your lift pump working? _____Y_______
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? ____Y_____
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? _____Y______
2d] Loosen an injector line and crank the engine - does fuel come out? ____Y_____
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? ___________
3] PMD / IP Issues
3a] Location of PMD (on pump, on intake, remote mounted) _____PMD on Intake, added second remote PMD to Radiator support______
3b] Condition of Extension harness (if used) Vendor or Homemade? ____new, vender_____
3c] Condition of grounds / ground wires to IP / PMD. Check Harness. ____clean & secure_____
3d] PMD Make: _____PMD 1 stanadyne w/flat heat sink on intake, PMD 2 w/finned heat sink behind drivers (left) battery on radiator support______
3e] PMD Age: _____PMD 1 unknown, PMD 2 new________
4] Stalling Issues
4a] Do you experience stalling only when hot? ______N/A______
4b] Does it stall under particular circumstances? (ie hit bump, or on accel) __N/A____
4c] Does pouring cool water over the IP seem to help with restarting? ____N/A_____
4d] Is stalling momentary (engine recovers)? ____N/A_____
4e] Does SES light come on when engine hiccups? ____N/A_____
4f] Does cruise control quit working when engine hiccups? _____N/A______
4g] Does re-starting seem to reset engine, restoring cruise and power? ____N/A_____
4h] Changes to dash lights or instruments during stalling events? ____N/A_______
5] Running Issues
5a] On cold start, does upper rad hose get hard before engine warms up? ___No____
5b] Any bubbles or oil film in coolant overflow tank? ___No____
5c] Any white slime on oil surfaces (dipstick, CDR, oil Fill cap)? _____No_____
5d] Excessive white smoke from exhaust on cold start? ____No_____
5e] Excessive black smoke from exhaust under hard acceleration? _____Unknown_____
6] Performance Issues
6a] Do you have gauges (boost, EGT) ? ______No_____
6b] Maximum boost under load? _____Unknown_______
6c] Have you added a performance PCM (reflash) or Chip? ______No________
6d] Have you changed exhaust / downpipe / crossover? _______No_________
6e] Wastegate – mechanical or vacuum (OEM)? ______Vacuum________
7a] Single or dual thermostats? ______Single______
7b] Have you replaced them lately? Manufacturer of replacements? _____New____
7c] Have you pulled and cleaned Radiator and coolers lately? _____drain/refill_______
7d] Have you replaced the fan clutch? Manufacturer of replacement? ____No, works properly____
7e] (winter) Have you tested your antifreeze? Good to what temp? _____Yes, Minus 25 degrees_____
7f] (winter) Are you using a winter grille cover? _____No______
____Found & replaced cracked heads with new heads with Felpro gaskets, new injectors, new glow plugs, new boost solenoid. Changed Fuel filter, air filter, oil filter, anti-freeze. Replaced boost hose._____________________________
My main question is will running this engine with 3 year old Diesel cause excessive tail pipe smoke (whitish/grey) The smoke smells of fuel, not antifreeze. Engine has only been run approximately 30 minutes. On short test drive (4 miles) noticed excessive exhaust smoke, oil level has not chenged, not over pressurizing coolant resevoir, level is also unchanged. Thanks in advance SMac :hello:
- Year: ___1994___
Diagnostics:
1] Starting:
3] PMD / IP Issues
4] Stalling Issues
5] Running Issues
