jrsavoie
Recruit
94 6.5 diesel K3500 died going down the road. Will not restart.
It died like it was a PMD issue. But never restarted like a PMD normally would.
Lift pump is working good.
The fuel shut off solenoid is working
Fuel filter is changed. Looked dirty but it still had good flow from the T/drain valve and the filter bleeder.
The injector pump return line did not seem like it had as much flow as it should,
Is it possible to back flow into the IP?
The PMD's are good. I tried different "known to be good PMD's and extension harnesses. No change = no start.
It is obviously NOT getting fuel. No smoke, no nothing.
The glow plugs are cycling normally.
I used to have a sheet on how to test the PMD. I seem to have lost it. Does anybody have a good checklist for the PMD?
I am going to double check the Injection Pump return line tomorrow.
Any other thoughts would be enormously appreciated.
Checked grounds and fuses - all good
If anybody is interested, I would pay for a house call. Near L'Erable, Illinois
I'm stumped
I'm stumped
