93 Delphi Lift Pump
nobby
Old Timey Diesel Guy
Long Island NY
Can anyone confirm if the part number for the 93 Delphi lift pump has changed? Prior threads list the pump to be a HFP905. However Rockauto and Delphi Online Catalogue now show a FD0009 for the 93.
Cheers
Nobby
For anyone else with the same question I found the following info:
The HFP905 is 9.5 - 14.5 psi shut off and the FD0009 is 4 - 6 psi shut off.
Also for anyone wondering the Heath Lift Pump specs out as follows, note this is a pump that is at least six years old, readings taken Post FFM (thanks Leroy):
Static shut off around 11 - 12 PSI
Idle 7 PSI
Heavy Throttle 4 - 5 PSI
Cheers
Nobby
