davo727
Well, I found out what was causing the loud rattle and clutch not disengaging all the way on the 92 Dually I trailered home, the prev owner parked it after he paid some goof to r/r the clutch and he screwed it up.
All 6 flywheel bolts loose, flywheel rocks back and forth about 1/2 in. Obviously not torqued and not locktited.
Dowel pin broke off in crank.
Has brand new solid flywheel, new disc looks like carbon friction linings , new pressure plate , old leaking slave and old grinding throwout bearing.
Bellhousing previously welded, will clean it up and inspect.
Im going to try and look up some numbers off this stuff to see if the parts are correct. Im going to replace the throwout and the slave cyl.
Somebody told me they thought there should be a shim between the crankshaft and the flywheel? Anyone know if that is true?
I have to get new bolts and dowel pin for the crank from the dealer. Thanks, Dave
