Im putting together a suburban with a 6.2 and 700r4 for my my girl friend so she has something that has more room for our little boy and im wanting to make it as simple to drive as possible for her. i have a 92 700r4 that i just built but i have it setup for a toggle switch for the lockup and she wont have clue how to use that so im looking to build aan early 700 that has hydraulic lockup. i have a good case and i believe i have the valve body still. my question is can i use all of the internal parts out of the 92 in the older case? it was a 27 spline originally and the parts ended up scattered everywhere so piecing it back together with original parts is probably out of the question. It has 3 pressure switches in the valve body for 2nd, 3rd and 4th and it locked and unlocked as it should when it was together all i had was a brake switch and power to the trans i didnt have a toggle switch or any thing it had constant power. If i can put all the later parts in the early case and have the hydraulic lockup im wanting id be set.
