Acesneights1
Is the starter for an NV4500 6.5TD different from a 6.5TD auto ? I get conflicting reports. I am having an issue over this. NAPA shows yes, Advance shows no. I would be referring to a 93 K3500.
The difference in offset"if there is one" will only be about 1/16th of an inch. Do you have them off Barry and can lay them flat and measure the offset ? Nothing is ever easy for me, always gotta be something that just can't be or no one has ever seen...:suicide:I went out and compared the GR starters off of manual trans and auto trucks. No difference. The flywheels off of manual trans 6.5-1 pc rear main and 6.2-2 piece rear main appear the same. I'm thinking the DD 24 volt military starter is T400 specific and the nose won't fit the flywheel behind the ring gear because the flexplate has no lip back there. Maybe compare DD starter listings for 80's 6.2 trucks ???
It's currently on a 6.2. Can you clarify which flywheel was which ? If I understand it right the top two are the manual Tranny ones and the bottom two(LUK and T400) are auto ? If that is the case then we are talking about .011 difference and I am hitting by atleast .0625(1/16 inch) if not more. Thing is I have a GR starter with the large opening and it hit as well. I hogged a good 1/8 inch off the DD one. It actually works fine so far.#1 GM flywheel #14050525N .333 offset [twards engine] of engine face of ring gear from mounting face of crankshaft
#2 GM flywheel #14050525N .344
#3 Luk flywheel #05c3a 05c3b .245
#4 GM T400 flexplate .240
I still don't get it if that flywheel worked in another 6.5 truck why not now???????
