rtdhsp
- Year: __95____
- Truck model and class (ie: c2500) __c2500_______
- Automatic or Standard __auto________
- Mileage: (indicate miles or km) __350000 km_______
- Replaced parts and mods (IP, PMD, chip/PCM, TM, injectors etc) _pmd relocate,newer rings and bearings__________
- Model: ‘S’ or ‘F’ engine, NA or Turbo, EGR? __'F' TURBO____________
- Ambient outside temp: (indicate *C or *F) __20 C________
- What fuel are you using? (#1 Diesel, #2 Diesel, Bio, VO, WVO, etc) _unknown.______
- What fuel additives are you using? ___________
- Where are you located? _CRANBROOK B.C CANADA____________
- Air filter __NEW______
- Fuel filter __NEW_______
- CDR Valve? ____?_____
- Coolant – last flushed/replaced at ______?_______
- Oil – synthetic/regular, changed at __SYNTHETIC ___(royal purple)______
- Batteries – state of charge, (matched set) replaced at FULL CHARGE,NEW___________
- Battery cables and grounds (removed, cleaned and tightened): ______YES________
- Glow Plugs - how many miles on them? _60,000KM________ What type? __BOCH___________
- Injectors - last changed at _60,0000______________
- What were you doing when it happened? __FULL THROTTLE__(from 20km to 50km)_________
- How was the truck running fine before this problem appeared? __PERFECT___________
- Has this problem ever happened before? ___NO____________________
- Describe any related factors that might be part of the problem. ______________
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) _Y___ And? _13,22,25 AND 63_______
Diagnostics:
1] Starting:
1a] Does the engine start? ___NO______
1b] Does the engine crank over? ___YES_____
1c] Are your batteries fully charged? _YES________
1d] Have you removed, cleaned, and tightened all battery connections? __YES_____
1e] Does your Wait to Start light come on for a time? How long? _N/A________
1f] Does your glow plug light come on? ___Y______ For how long? __6 SEC______
1g] Do you see smoke from the exhaust while cranking? What color? _NO_______
2a] Can you hear your lift pump working? _YES__________
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? __YES_______
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? ______?_____
2d] Loosen an injector line and crank the engine - does fuel come out? ____NO_____
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? ____no_______
3] PMD / IP Issues
3a] Location of PMD (on pump, on intake, remote mounted) _on intake__________
3b] Condition of Extension harness (if used) Vendor or Homemade? __vendor_______
3c] Condition of grounds / ground wires to IP / PMD. Check Harness. _good________
3d] PMD Make: __STANADYNE_________
3e] PMD Age: __?___________
4] Stalling Issues
4a] Do you experience stalling only when hot? ___NO_________
4b] Does it stall under particular circumstances? (ie hit bump, or on accel) _NO_____
4c] Does pouring cool water over the IP seem to help with restarting? _____?____
4d] Is stalling momentary (engine recovers)? __NO_______
4e] Does SES light come on when engine hiccups? ___NO______
4f] Does cruise control quit working when engine hiccups? ___NO ?________
4g] Does re-starting seem to reset engine, restoring cruise and power? ______n/a___
4h] Changes to dash lights or instruments during stalling events? ____no_______
5] Running Issues
5a] On cold start, does upper rad hose get hard before engine warms up? _______
5b] Any bubbles or oil film in coolant overflow tank? _______
5c] Any white slime on oil surfaces (dipstick, CDR, oil Fill cap)? __________
5d] Excessive white smoke from exhaust on cold start? _________
5e] Excessive black smoke from exhaust under hard acceleration? __________
6] Performance Issues
6a] Do you have gauges? _NO________
6c] Have you added a performance PCM (reflash) or Chip? __NO____________
6d] Have you changed exhaust / downpipe / crossover? _STRAIT PIPE 3''_______________
6e] Wastegate – mechanical or vacuum? ____VACUUM__________
7a] Single or dual thermostats? __SINGLE__________
7b] Have you replaced them lately? Manufacturer of replacements? _____NO____
7c] Have you pulled and cleaned Radiator and coolers lately? _1 YR___________
7d] Have you replaced the fan clutch? Manufacturer of replacement? __REPLACEMENT______
7e] (winter) Have you tested your antifreeze? Good to what temp? ___NO_______
7f] (winter) Are you using a winter grille cover? _I WILL__________
when it died the fuel sol fuse was blown,the pmd smelled burnt.with the new pmd the fuse is fine.I removed the fuel solenoid,tested fine.cracked the injector with no fuel. COULD AN ANGRY PMD TAKE OUT THE OPTICAL EYE OR SOMETHING ELSE ON THE IP ? :mad2:_________________________________
__________________
Diagnostics:
1] Starting:
3] PMD / IP Issues
4] Stalling Issues
5] Running Issues
__________________
