Anubis
Being fat sucks
Delphi 6.5 non-turbo injectors. 126 bar (something like 1877 PSI) will they work in a turbo application?
Delphi pn 6703802
Delphi pn 6703802
Depends totally on the pintle design,you won't know unless you take it apart, if its flat sided your good to go.
I would pass, but if you have already bid and win,you can change nozzles if they are the wrong ones.
The first injectors I found was item number 280459558021 Ohio Truck Parts, the second set the item number matches yours, they look the same ,green caps, I'm tempted to bid on the Ohio ones just to see if the nozzles are any good,can't beat the price.
I just had my injectors pop tested at a local shop. The guy called saying that 5 of the 8 were pressured for a non-turbo engine (500lb difference), and asked if I wanted them fixed. I said sure - and I would have to assume that all 8 are now at the same pressure. It was 12/ea for pop testing and 15/ea for pop/fix.
If you bought non-turbo injectors, could they/you just readjust the pressure for/in them?
I have discussed this with tim from accurate diesel. he said I can adjust the pop pressure.... just need a pop tester.... I bet I can use the shims from the injectors in my truck........
