truck is,, 1998 GMC 2500HD 6.5l TD (vin F)
ok,, at the beginning of last week the check engine light came one and the truck poured like a greyish colored smoke out,, checked the codes p0236 (turbo boost sensor A circuit),, when that code came up i thought to my self that i dont remember hearing the turbo when this happened,,, so i backed it out of the garage and got on the brake and built the turbo up,, i could hear it spool up,,, i left off at a little less than 2 grand,, but i heard like a click and the check engine light went out,,, since than the truck has ran like normal,, (no issues)
well today on my way back from carlisle (about a 3 hour trip) the check engine light came on and i looked back and saw grey smoke again,,, as i was driving i noticed the turbo was not spooling,,, i couldnt hear it,, i got about a hour away from home and the light went out and the turbo kicked back in,,, for the rest of the drive the turbo would go work and than stop,,, and work again a little later,,, when it wasnt working the truck poured smoke out when i was on the throttle,,,,
do you think i have a bad turbo??? or is there something else causing this??
