racedaymechanic
These GP Harnesses are about as bullet proof as they can be. 12 Ga High temp wire 1000 degree insulation on all the critical points, 100% protected by fusible links, and even a new lead and connector for the ECM signal wire, The lengths are longer overall and makes routing it better than factory routing, all Heat Shrink is water tight and Oil resistant, It is all Millitary Grade. This will fit any Chevrolet/ Gmc 1500, 2500, 3500, Z71, Tahoe or Yukon equipped with the 6.5 Turbo Diesel, The cost is $175.00us + $10.95 Shipping for the lower 48 add $10.00us For Canada
