OK first off thanks for any help here.
1994 C3500 6.5. Bought 2 month ago Ran OK. Check engine light would come on after drining 1/8 mile or so but go off after engine shutdown. bought Code reader and looks like Injector 7 is bad but have had to drive it off and on. (only a farm truck) Went to NAPA to buy injector and stalled and had to push back into parking lot but started after a min or 2 and run ok. Got home and parked over for about 2 hours. Went out to move into garage to put in injector and started right up drive 20 feet and died. Has not stated again. Cranking fine, Checked all fuese. Glow light come on and stays on when cranking but will go out after i stop cranking but comes back on after a key off and back on. Tired WD40 in intake (new type) but did not act like it wanted to start at all. Can hear fuel pump kick-in and run for 5 sec after cranking, opened top of fuel filter and getting fuel on crank only. Change out filer as it was due anyways. With key on it does not fill the fuel filter housing but dues when cranking. Broke down as did either, (YES I know, :nono: ) but was not acting like electical. With a shot of either she tried to run so not electical but fuel. When key is on and I un-plug 2 prong flug on injector pump (comes off top of cylander about size of a rool of quarter i hear i click when I put back on. (Think that is the feul shut off????) not sure. So then I took off the fuel line to the #1 injector and get no fuel on crank.
1. Could it be air in injector that need to be bleed? How do I check this?
2. Could it be the injector or fuel shut off? How do I check ?
3. Any other ideas? Thanks a million in advance.....
Jonathan
Down in delaware!
Jonathan
Down in delaware!
