6.5 Engine stutters
Gunar
Chemnitz/Saxony/Germany
Hello Friends,
I got replaced my Headgaskets -Engine runs good- but when I want to accelerate then had the Engine misfires(he stutters).
I have a code 62-needs the Engine the Turbo Boost Sensor also for the Diesel/Air Mixture?(My problem is also that I can't find the Plug/Cable that going to the TBS - I've been looking everywhere - I find it no more...)
Thank You for your Help!
Gunar
Its the black rectangle sensor on top of the upper air intake. White connector with three electrical leads. It is most likely under the lower intake manifold in the passenger side of the IP. Those wires are wrapped in a loom and branch out with the ones going to the Air Intake Temperature sender (round, two wire connector) also on top of the air intake. Follow the Air Intake Temperature sender's wires down back to the "Y" or branch and you'll find the connector for the Boost Sensor.
Добрый день Павел;)
I know where the TBS is located - I must look again or build down the Intake Manifold...
Do you know whether this the Diesel/Air Mixture also influenced?
Спасибa
Gunar
