What are your plans for it? Offroad, towing, daily driver? This is the most important question to build the rig for.
What's leaking and how bad? Once you pull the engine and find out it has cracked main webs... Better not to know sometimes. Re-seal and gapless rings to help blow-by... IMO these rigs never stop sweating power err... leaking something even when new. If it quit leaking it means it ran out of oil!
Why the hi-pop on the injectors? You have a IP Pump builder backing this decision up? If you run into white smoke, no hot starts, and general drama starting... Just saying I am literally changing the 2350 pop injectors out of my truck this past weekend after fighting hard starting for 5 years. Generally use the turbo pop pressures unless you have a custom built pump. The turn-key ease of starting like my 1992 project truck with standard turbo pop pressure or 2350 pop's 1/2 to full throttle in reverse with the brakes on watching white smoke fog rolling in till all 8 finally light off. Just saying it didn't work well for me nevermind going through several pumps.
You reach a fuel limit with NA precups AND big turbo's. You won't notice NA precups with a small GM sized turbo because the turbo is the restriction.
84-85 surplus military 6.2 NA's I have run didn't like all the fuel I could throw at it. Had a hard time clearing the smoke at any RPM with 17+ PSI boost off the ATT. Careful tuning got it to 6.2 NA levels.
I am leaving a stop light with AC on, Fan locked up, over 100 degrees of hot dry air outside, with or without a trailer. Blowing smoke till the damn thing starts spinning 2000 RPM where the big turbo lights off. Big turbo's change the RPM range of the engine: once you understand this trade off the better you will enjoy it. 2000 RPM pulling like a freight train till read line rather than fighting a small Asthma Attack small turbo all the way to red line. I have used a BD Spool Valve and finally a Yank Stall converter to "slip" the engine past 2000 RPM from a stop light. On my build you got a second or so after pinning the throttle before the turbo lights and then the rear wheels light.
I generally built it to tow 550 miles a day over grades beyond 7% that go for miles. YMMV
