QinVB
Hello all. Got a situation that I think is worth considering, but I need the knowledge and expertise of the members of this forum. I will appreciate feedback"
I have a 1990 6.2 with 116K original in an (another) exCity vehicle that had oil changes every 3k that runs really well and which I've replaced needed parts to anticipate and avoid problems because I used it in my business which is now history. It's in a ratty P-30 that would be better off going to the recycle center as a load of steel scrap. I have a chance to get a 2004 2500 4x4 with a blown 5.7 sb cheap. The 6.2 has the HD 400 3spd auto with the straight cut gears. The 04 has a 4l80E. I know anything is possible if you want to do it badly enough, and I'm sure someone has done it already. But, my question is: is it worth the effort? Would this be a relatively easy swap with some fabrication, and wiring mods, or should I pass? Electrical mods wouldn't be a problem for me, I'm good with that. I figure I'd need motor and trans mounts, bell housing, torque converter, may be able to reuse the exhaust, and the front of the truck would need to come apart (see War Wagon's pictures).
I think the '04 could be a great truck with that engine, for what I need, if it is possible to mate the 6.2 with the 4L80E/transfer case to make it work. Many new parts on the 6.2. I feel confident it would last, but it's in something that I really don't like to drive.
Opinions, suggestions????
