jmack91z28
Jason
Well I kinda changed up again on a 6.2 project. I've got the engine and 4l80e sitting around. I gotta do something with them. Still got the 96 gmc for sale... someone please buy it.
Bought a 91 Suburban, GMC. V2500 4.10 gears NP241 350 tbi and TH400.
I want to replace the driveline with my 6.2/4l80e. Already got the 6.2 stripped down to the longblock. Been doing a lot of research and gathering up pricing and details. Talked to bill the other night about his NA-66 cam setup.
Plan so far is: Bills cam and springs, rebuilt DB2 .29 IP, have the bosch injectors rebuilt, new bearings, gaskets, timing set, fluidampr. Everything else stock.
4l80e I'll have my transmission guy freshen it up and swap out the output shaft and tail housing to bolt to the 241 transfer. Have the driveshafts resized. Already talked to Leroy about the tcm kit he sells.
I'm going to changed out the brake system for hydroboost. Can do it all off of rockauto for about $450. That's booster, master cylinder, hoses and power steering pump.
New fuel tank, sender, frame mounted lift pump, lines and fuel filter setup. New engine oil and tranny coolers + lines and fittings.
Then all the misc stuff like wiring for GP's and a second battery. I'll worry about A/C later.
