jmack91z28
Jason
Finally got around to getting the 6.2 out of the bread truck and I've already started stripping it down. I'll post up some pictures at a later time. I'm wanting to rebuild it with a 6.5 top end and most likely an A-Team turbo. Need some advice along the way as this is my first diesel build here. I'm going to ask plenty of questions along the way as I know you guys are a wealth of knowledge.
The 6.2 is a 93 model with 140,000 miles and a 599 block. I've been told these 93's have 6.5 heads and injectors but I haven't verified that yet.
Plans are complete bottom end rebuild, prefer to lower the compression as well, maybe 20:1? I'm not planning on running more than like 14psi. I'd like to go with gapless rings and ARP head studs. New cooling setup, waterpump/fan/clutch/single stat neck. I'm going to have the block cleaned and pressure checked, same with the heads. DB2831 injection pump with stock injectors. I'd like to talk with bill about his towing camshaft too.
I'm staying with the 4L80e and will be buying a TCM setup to make it work. I'm obviously going to have to have a set of gauges as well, new Delco balancer too. I'm not going to waste time and money on a stud girdle or Fluidamper..
First question is, where can I get a solid rebuild kit with lower compression pistons and gapless rings? Or am I going to have to piece all this together?
