Im going to sell this engine and buy a P400.
I have the short block built with all new Piston rings that are gapless by Total Seal, Power honed, crank was polished (not turned/ground), bearings, oil pump, cam bearings, oil pan for GMT 400 or Hummer. Block was hot tanked and no cracks.
As far as the rest, I have ready to go with new ARP head studs, enlarged precups all gaskets/seals. Heads have no cracks. These engines have better metalurgy and are stronger than the GM blocks.
Im probably forgeting something but its a complete long block with heads off. I can install the heads if wanted?
I can of course outfit the engine anyway you might want it with ATT turbo or Fluid Damper, Harland Sharp rocker arms.......ect let me know.
I bought it from Teds for $3800 plus shipping then have added all the above parts of atleast $1000. Im not charging any labor.
So if your in the market for one of these I don't think its a bad deal at all when you add everything up.
Im asking $4950. Less than you could build same engine for. Cash or wire transfer (no Paypal or credit cards)
[email protected]
[email protected]
