muddycowboy
BERR
ok so my wife took my 95 K2500 to work the other morning and had to come back home cause it would not shift past 2nd gear, mind u it was 0 degrees. i looked at it that evening and had no problems with it. i checked the fluid and test drove it with no problems. now a week later i noticed that it is running higher trans temps.
it is a Jasper brand trans. last summer i changed the fluid/ filter, installed a B&M deep trans pan, larger B&M trans cooler out front, and a trans temp gauge. it use to normally run between 120 to 140 depending on driving style, without heating up fast. now in the last week it is heating up quickly ( 5 miles rural, under 55) and is running around 160 degrees.
Any Ideas on what could have happened? thanks
