btsayles
Diesel Proficient
I'm getting so tired of this truck. All I do is work on the darn thing. I replaced all of the electronics in the trans and now it shifts into 2nd very hard. Not to mention that other gears also, but it is hardest into 2nd. I also installed a deep transmission pan and new filter. I originally replaced the electronics to get the torque converter to start locking back up again, but I don't think it fixed that either. I can't tell if the convertor is engaging or not. It's irrelevant either way if the trans blows up from hammering into gear. Another strange thing is that when shifting from 1st to 2nd with the lever, it takes it a second or two for it to shift and it shifts hard. When I put the lever in 3rd, it stays in either 1st or 2nd and won't shift into 3rd at all. THen when I shift it into D it will go through all of the gears. What is going on? It shifted lazily prior to replacing the electronics, but I would have driven it that way rather than dealing with this. This is starting to wear on me. It's going to snow soon and I need my plow truck.
