amazinblaze
- Messages
- 1
- Reaction score
- 0
i have a 1991 k2500 recently my reverse went out it has a initial shudder when you put it into reverse then nothing its like fluid pressure i can rev it up dangerously and it will go in once its in its in the warmer it gets the better it gets i have changed alla the electronics on the trans wiring harnesses included ive pulled the valve body the plate holes for the check balls was worn badly i replaced the plate with a new one took all the valves outta the valve body and cleaned it good pulled pressure regulator outta pump replaced seals on reverse servo naturally i checked the band its not broken i even changed the tps there was nothing in the pan initially when i took it off just sedimate but like i say ive cleaned everything i even air pressure checked everything. the force motor they give me is a black one supposed to superceed the silver one the new plate omited the hole for the old one and i had to drill an additional hole in the valve body for pressure relief transgo 48-plt-o1 any advice would really be appreciated as this thing is making me go bald scott
