4l80e no lockup
keffa
spokane
Help I have a 4l80e that will not go into lockup. I have all gears no trouble with up or down shifts. lockup rarely occurs like it use to in 3rd gear at 47 mph or 4th at 65 mph. it has 171,000 miles on it. Had anybody every had a brake switch cause this issue. Once ago I had an ignition switch go bad and it would send fire no fuel, or send fuel no fire. I have all gears but no lock up. Has anybody found a switch problem that could cause this?
check the temp sensor on drivers side head.
What kind of truck and motor do you have.
Welcome to thetruckstop. Take a few moments to fill out your signature for us so we know what you're working on. Without knowing what you're working on, none of us can provide you much if any help. We need to know year, make, model, 2 or 4 wheel drive, any recent work done, did the problem occur all the sudden or gradually, any codes present? The more details we can get, the better we can help you. There are DOZENS of different things ranging from a bad coolant temp sensor, TPS, lockup solenoid, failed converter, trans fluid temp sensor, speed sensor, brake switch, and several others.
