ak diesel driver 6.5 driver Messages 20,011 Reaction score 21,619 Location alaska Apr 26, 2011 #1 Are the adapter plates on the cummins universal? My step van has a ford 4 speed and I'm wondering if a nv4500 would bolt up to it
GM Guy Manual Trans. 2WD Enthusiast Messages 4,848 Reaction score 876 Location NW Kansas and SC Idaho Apr 26, 2011 #2 I do not believe so have you considered a ZF5 or a ZF6 with the ford pattern instead? I feel that it would be cheaper to go to cummins, as I doubt anyone would part with the chevy one from a 4bt frito lay van. are you planning a 4bt swap, or do you use the van for work?
ak diesel driver 6.5 driver Messages 20,011 Reaction score 21,619 Location alaska Apr 26, 2011 #3 I already have the van with the cummins (see sig). I was thinking of a nv 4500 for the low 1st and the overdrive.
A Acesneights1 New Member Messages 10,018 Reaction score 36 Location Northeast CT Apr 26, 2011 #4 Go to NV4500.com. They have every adaptor known to man but better have a large credit limit on your card...$$$$
GM Guy Manual Trans. 2WD Enthusiast Messages 4,848 Reaction score 876 Location NW Kansas and SC Idaho Apr 26, 2011 #5 ak diesel driver said: I already have the van with the cummins (see sig). I was thinking of a nv 4500 for the low 1st and the overdrive. Click to expand... I was meaning are you using the van, and just wanted the benefits of overdrive, or were you gonna swap and really wanted to use an NV4500 in the swap?
Burning oil LeroyDiesel.com Vendor Messages 10,306 Reaction score 1,974 Location Houston Apr 27, 2011 #6 On the two adapters I have they are GM specific. It has two bolt patterns one for Chevy and one for Pontiac, Buick, Olds..... So its posible yours could have more than one bolt pattern also??
