3 or 4 inch exhaust or not
RD400HP
Active Member
Fowler, Ohio
I have a 95 with a 6.5 NA what I would like to know is would it be worth it to consider a larger exhaust system and if so which one 3 or 4 inch? Thanks.
Mark
Thanks for the reply Jorge is this a system that you could buy off the rack or have to be custom made? Thanks.
Mark
Most any exhaust shop could make up the true dual system no problem or just about any kind of setup within reason. IIRC the 6.2s came with true duel exhaust, maybe a system from them would work?
If you do some searching on the site here or google im sure you will get lots of results.
Is your truck an n/a from factory? Have you considered turboing it?
Yeah Jorge it is a factory NA.with 160K on it. When I first bought it I was going to do the turbo upgrade but as of late I've thought against it for right now. I'm putting a F intake on it to get rid of the old round air cleaner and I'm going to get a S&B cold air intake for it so at least I'm kinda collecting parts needed for the turbo upgrade if I should choose.
Mark
