Anubis
Being fat sucks
These questions are GMT400 specific.
what are the differences between the LD 2500 and the HD 2500 (besides the LD is 6 lug with a 7200# GVWR)?
I know the axles are different....... but can the 8 lug hubs be swapped in place of the 6 lug on the front (looks like he 8 lug spindles are 4 bolt and the 6 lug spindles are 3 bolt) or are the arms too much different.... can the arms be swapped, would SAS with an 8 lug Ford axle be better?
are the frames different (like the 97 non SD F250 is on an F150 frame)?
the HD 2500 has the 10.5" FF and the 6 lug has the 9.5" SF (equivalent to a D60?). Is it just as easy as swapping in the ff 10.5" or are the springs different?
are there differences in the brakes?
are the Transfer cases different?
I have a 4L80E so the transmission should be the same.
The IFS is worn out on my truck. If I have to go through all the crap to change all the bushings and joints, spindles, hubs, Brakes, shocks, steering components, and what ever else ...... I might as well convert it to 8 lug (and what ever else) and get a true 3/4 ton, but there is this guy named Murphy that likes to mess with all my best laid plans.
