2005 Dmax pass window slow to go up can stall.
WarWagon
Well it hits on 7 of 8...
AZ
The passenger side window stalled while going up today. I started the truck and the higher voltage allowed it to go the rest of the way up. It has always been slow to go up. (Truck started but batteries were a bit down from extended use with engine off.)
Is there any common failures to 2005 that would cause this window to be slow or stop? Connectors at the switches looked good.
Most of teh time it is dirty tracks that nee to be cleaned and then lubed with silicone grease. the last one I had though ended up breaking teh window regulator as it was binding teh cable on the drum at the motor.
Found the window was hanging up on the edges. Took apart and cleaned motor out and reoiled it, lubed track, then took a BFH and pounded a large screwdriver in the seal by the mirror to make some room. Still hung up. Then I got some LPS #1 dry lube and hit the seals at the ends by the mirror and back of the door. The LPS on the seals made the most difference. Just lubed the "edges" for the window NOT the dust seal strip.
Works better now.
