Acesneights1
Anybody got a wiring diagram for the crank circut on my 2000 GMC k3500 6.5 ?
Got in it today hit the key got lights glows jiuce etc but no crank. Leaning towards possible neutral safety switch because I slammed the shifter few times into park and it started but then it did it again and now sits dead in the driveway. Never had to deal with it on one of these newer trucks. is the crank circut looped through the PCM or is it old school, key->neut switch->starter sol.
Lights not getting dim or anything just no crank. ONe note. PO must have replaced or screwed with the ign switch because if you shut it off and take the key out the pointer on the gear sel stays lit. If you leave the key in and turn it a c hair back towars accsy it goes out plus the accssy pos never worked but it's been like that for 2 years. Do have mouse problems around here so either I'm thinking neutral safety switch or little bastars ate the wires somewhere. Anyway if anybody has the print for the crank circut that would help alot before I crawl under it tommorow.
