Problem: Explain your problem in concise language (ie: Cranks but won’t fire). Cranks and Fires (very intermittantly) but does not start or come close to starting
- Year: 1997
- Truck model and class (ie: c2500) 3500
- Automatic or Standard Auto - and Auto 4WD
- Mileage: (indicate miles or km) 255000 Miles
- Replaced parts and mods (IP, PMD, chip/PCM, TM, injectors etc) PMD couple months ago
- Model: ‘S’ or ‘F’ engine, NA or Turbo, EGR? F (Diesel)
- Ambient outside temp: (indicate *C or *F) 40 F
- What fuel are you using? (#1 Diesel, #2 Diesel, Bio, VO, WVO, etc) Pump Diesel (though truck does see well heated wvo)
- What fuel additives are you using? None
- Where are you located? Pennsylvania
- Air filter 2 yrs ago
- Fuel filter Unknown
- CDR Valve? Unknown
- Coolant – last flushed/replaced at 2 yr ago
- Oil – synthetic/regular, changed at 245K miles
- Batteries – state of charge, (matched set) replaced at Both are new in last 3 months
- Battery cables and grounds (removed, cleaned and tightened): last 3 months
- Glow Plugs - how many miles on them? Within 500 miles What type? AC Delco
- Injectors - last changed at Unknown
- What were you doing when it happened? Replaced Glow Plug Relay, Started Truck, Idled fine for 10 minutes, then stopped
- How was the truck running fine before this problem appeared? Fine
- Has this problem ever happened before? No
- Describe any related factors that might be part of the problem. Old Truck
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) Y And? None
Diagnostics:
1] Starting:
1a] Does the engine start? No
1b] Does the engine crank over? Yes
1c] Are your batteries fully charged? Yes
1d] Have you removed, cleaned, and tightened all battery connections? Yes
1e] Does your Wait to Start light come on for a time? How long? 4-5 secs
1f] Does your glow plug light come on? ____? Same as Wait?_____ For how long? _________
1g] Do you see smoke from the exhaust while cranking? What color? No
1h] Does the Service Engine Light Glow during Start/bulb check? Yes
2a] Can you hear your lift pump working? Not Sure (A two man test)
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? _________
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? ___________
2d] Loosen an injector line and crank the engine - does fuel come out? _________
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? ___________
3] PMD / IP Issues
3a] Location of PMD (on pump, on intake, remote mounted) On intake manifold top
3b] Condition of Extension harness (if used) Vendor or Homemade? Decent - probably Vendor
3c] Condition of grounds / ground wires to IP / PMD. Check Harness. Looks Decent
3d] PMD Make: Newer Grey Type
3e] PMD Age: ?
4] Stalling Issues - N/A - does not start
4a] Do you experience stalling only when hot? ____________
4b] Does it stall under particular circumstances? (ie hit bump, or on accel) ______
4d] Is stalling momentary (engine recovers)? _________
5] Running Issues - N/A does not start
5a] On cold start, does upper rad hose get hard before engine warms up? _______
5b] Any bubbles or oil film in coolant overflow tank? ______No_
5c] Any white slime on oil surfaces (dipstick, CDR, oil Fill cap)? _No_________
5d] Excessive white smoke from exhaust on cold start? ___Perhaps (before this issue)______
5e] Excessive black smoke from exhaust under hard acceleration? __No________
6] Performance Issues - N/A does not start
6a] Do you have gauges (boost, EGT) ? No
6c] Have you added a performance PCM (reflash) or Chip? No
6d] Have you changed exhaust / downpipe / crossover? Yes - recently
6e] Wastegate – mechanical or vacuum (OEM)? OEM?
7] Temperature-related Issues:N/A
7a] Single or dual thermostats? ___________Single?_
7b] Have you replaced them lately? No Manufacturer of replacements? _________
7c] Have you pulled and cleaned Radiator and coolers lately? ____No________
7d] Have you replaced the fan clutch? Manufacturer of replacement? _No_______
7e] (winter) Have you tested your antifreeze? Good to what temp? ___No_______
7f] (winter) Are you using a winter grille cover? __No_________
I purchased it 2-3 yrs ago and it had some hard miles on it. The PMD that is currently on it was the newer Grey type and came with the truck. I had throttle control issues this last summer and it finally got bad enough that I replaced the PMD and a couple of other throttle related parts. The PMD cured it then.
Now It does not come close to starting, fires once in a while, but acts like timing is off. As mentioned above, it was idling, then a noise for about 2 secs, then idle for a couple of secs, then nothing. The noise could have been a timing chain grinding or slapping on the cover, or not. I suppose that a complete lift pump failure would be a possibility.
