View attachment 91627View attachment 91628None is supposed to be there. the pedal arm only has the rod that goes to the master cylinder, then the brake switch, then the metal retaining clip. There is no bushing, no washers, nothing else.
Use a pick hook to make undoing the retaining clip easier, then rotate the brake switch to get the plastic hook that holds onto the rod free. Then it’s easier to undo the harness connector. Then the switch slides off. Slide on new switch, clipping the plastic hook onto the rod. Then put the electrical connection back in (much easier with the switch hooked) then fight the clip- usually dropping it two to three times in the process.
It’s important to remember to bang your head a couple times, and wish that when you were a kid you had learned to become a contortionist. Pick your angry words before starting so your dog (or cat in Marty’s case) doesn’t think they are in trouble.
I circled in blue the plastic hook built into the switch that holds the arm.
