1995 OEM Condenser thickness 1.5" - replacement P/N is 1-1/8" and will not fit.
WarWagon
Well it hits on 7 of 8...
AZ
Just pulled out the 1995 condenser and compared it to the dealer item GM part number 15-6814 or 52458719 . I have rear air. The brackets and cushions do not work with the new and thinner part number. Part was VIN specific and Rock auto and Oreillys both list 1-1/8" replacements.
Is this the correct part? The lines will match up. Do I need new brackets and cushions?
I can't find a 1.5" replacement. I would like a 1.5" replacement out here...
150 LBS of air doesn't get much flow through the original unit so I need to replace it.
My replacement was alot thinner than the origanal as well. It was a completely different style unit though. As for mounts, can't help you as I had to modify mine to fit it in with the intercooler.
