I forgot to add the crank sensor was the first replacement done.....ops is delco...I'm used to working on gas so this is a little different of coarse.....all this work was done by someone else and I'm stuck here trying to fix it up.....Anybody now if the black box is in fact a ABS control module or some other kind of module.......one strangle thing with this truck is it has a MAP sensor hooked up to the wiring but no solenoid or vacuum attached to it....it only has one solenoid with wastegate and air pump hooked up
That would be the baro sensor for altitude. Not that the ECM does anything with it, but, it is there. Decoration that when removed trips a code... Not part of your current issue.
Yes the black box you ask of is a ABS unit for the rear wheels and NOT part of your current problem.
Stalling after 10 min.
Sounds like you have thrown parts at it without knowing why. This gets expensive and a good chance of a bad replacement part making things worse. I suggest we troubleshoot it before buying more parts. An old IDI diesel like ours, unlike a FI gas engine, will run a short time with fuel system problems then stall out. (Generally if anything fuel related quits on a FI gas engine it is not going to start again for any amount of time till it is fixed.)
Where is the PMD located? Where did you get it and is the 'extension cable' made in China if the PMD is relocated?
Pull a sample of fuel from the water drain into a clear container. Smell for bad smells, gasoline, and let it sit for 10 min. Did water settle out? Assuming the fuel is good we continue.
Put a clear 1/4" line off the IP to the fuel return rail on the front of the engine. You want to check for air bubbles. Especially after the engine stalls out. You also want to check fuel pressure at the water drain. "0" to whatever gauges are NOT the proper tool for the job. These systems will pull a vacuum and boil diesel to a vapor lock state with a kinked hose, plugged tank sock, etc. and your gauge needs to show this if it is happening. It needs to be a pressure/vac combo gauge.
Rev the engine to the point the governor holds the max 3600 RPM and check for some fuel pressure at that RPM. The IP bypasses a lot of fuel esp at high RPM. This will help eliminate plugged tank socks, kinked hoses and other fuel system restrictions.
Any codes? Use a paper clip to read out the codes if you need to.
Simply put you are running 10 min until you run out of fuel or something electrical gets hot and quits. Aka fuel system restriction or PMD if I were to guess with grounds, and ignition switch/misc wiring coming in 2nd.
I assume, but, have you looked at the fuel and air filters?
