1988 SM465 oil
iamdave0887
Here Comes Chaos.....
CT
According to the Amsoil catalog my 1988 SM465 calls for 5w-30 Transmission Oil. That sounds awful thin for that trans. I know the older SM465's used 80w-90 gear oil.
Exactly what does this trans take for oil?
Thanks guys
- Dave
30 weight engine oil has the same kinematic/saybolt viscosity as 80-85 weight gear oil. Either should be fine, the 5w-30 will provide better cold operation in the winter.
So i'd be ok with the 5w-30. it's a transmission oil according to the Amsoil catalog. This truck's primary use will be in the winter.
Would it be a good idea to swap the fluid to 80w-90 in the spring time until say the end of summer and then go back to the 5w-30 transmission oil, or just run the 5w-30 transmission oil year round?
