The 8.2 is really a big brother in similar idea of fuel efficiency instead of high power, and suffers same faulting areas, although for slightly different reasons.
the crankshafts break- so inspect your harmonic balancer frequently. First sign of the rubber cracking- replace it. Parts getting harder to find, you might start shopping now for one. Other than the rubber going bad, there is no warning, and with this engine- the balancer goes at 9:00 am and the engine is done at 9:03.
The other issue is heat and a weak head gasket design. The only thing you can do for this without upper end rebuild is keep the turbo boost low, and keep the engine temperature low. I like the 8., it is a nice engine when everything is in check. But they pop headgaskets like no other Detroit ever, Seriously worse Detroit for this.
If you ever pull the heads- get the thickest gasket you can for it (used to be a 20 thou over) and put head studs in. That open floating cylinder design doesn’t seal well on the gasket in the first place, then only 4 bolts per cylinder was poor design.
At the first sign of overheating, stop! These engines hydrolock pretty bad from it. If you catch it quickly- studs and headgasket with intake gasket is all you need.
do not push this engine to high rpm. Drive it like a 90 year old granny who left early but doesn’t want to be the first one to church.
When the engine is new- they could be ran hard, but man the ones I had in my fleet were all over 100,000 miles and didn’t stand up well. Could be the high heat here really beat them up?
