GM Guy
Manual Trans. 2WD Enthusiast
Hey all,
I picked up a 09 C3500 6.0 gasser for parts off an auction, unknown condition. Upon pickup, I have reason to believe all that is keeping this thing from running is getting the passlock module to talk to the key. I think the company who sold it lost the key and tried swapping a key and tumbler out of some other gmt900, as the key i had cut by the dealer to match the VIN before I went to pick it up (I was told there wasnt a key, luckily there was a key) will work in the doors but wont work in the ignition. current ignition key is a cheap dorman all metal key with no plastic trim, and the lock cylinder plastic looks newer than the rest of the dash plastic.
I have a tech 2 with a Candi module and had it plugged in last night, and could get to the key area of the tech 2, but cant seem to initiate a relearn, but I also am not experienced with the tech 2. It did tell me that there are 2 stored keys and zero authorized keys present, which seems to confirm my suspicion that they swapped the key and tumbler.
Is key programming possible with just the tech 2, or do I have to be hooked to a programming laptop (TIS2000?) with security access?
If I have to have the programming laptop, is it possible to instead program a new cylinder and that new GM key I had cut with the old 3) 10 minute key cycle method? I really dont want to try and learn the current key because its not the right one, and not even sure it can relearn an all metal key as I was under the impression the magnetic chip is in the plastic shroud and is necessary for passlock operation.
any input appreciated,
Thanks!
Thanks!
