stop and get you about 6 to 8 feet of heater hose and some clamps so when you can, replace that hose. might also do the replacement at the auto parts store so if you need a fitting youll be right there.
as for the gauge, it can change if the voltage is high, but a high output alternator shouldn't effect it unless it's pushing more than 14.5 volts. ideally you want to see 13.5ish volts regardless of what the alternator is capable of. you could have the auto parts check the charging system for free while your there. if your voltage gauge is showing normal, then it might just be a failing oil pressure sensor. it's rare that a gauge fails.
only other thing that I can think of is thicker oil if the engine is still cold and its really cold where your at.
Oh boy,
If it is the oil pressure sensor....how ****ed am I.
If it is just the sensor- you’re not. If the oil pressure is dropping- stepmone is checking oil level.
Feel consistency of the oil, make sure it’s still thick, and no fuel mixed into it.
Low pressure for one of these reasons needs addressing.
For reference, I am running 5w40.
Im actually finally in my hotel, ill wait a bit for it to cool down so I can do the clamp and hose change, and let the oil get back into the pan. Ill check the level afterwards.
Update:
Trip is back underway, im making a beeline to NY at this point, got a mouth wired shut, cant stand this anymore
Starting:
Weird noise made by starter:
(Not sure what that noise was, not the first time its done it either, im currently in PA now, 6 hours from NY)
If you are talking about the high pitched sound that lasts about 1 second the instant the engine stops cranking- that is the starter free spinning.
Basically the engine “bucked” as in:almost started. It speeds up faster than the starter for just a moment and the starter automatically disengages (which is what it is supposed to do). But your finger is still holding the key to start when it happens. So the motor part of the starter is spinning but the gear isn’t engaged into the flywheel teeth.
There is nothing wrong with the starter- it’s doing what it should. It’s just because the truck is not starting as easily as it should.
Getting a jumper wire into the temp sensor wires should help that.
Im posting a pic from a short video. I circled in yellow a red square light just above the tachometer in this newer 6.5 pickup.
The video shows his staying on for 6-7 seconds. Your’s should do the same.
I’m 99% convinced it’s because of that temperature sensor. Right now your engine thinks it’s about 160° right now so it is immediately turning off the glow plugs. Watch how it is supposed to act in the video.
Well boys, the K5 made its way to NYC.
Now im over worried about it rusting out 😭, i already washed it, but theres still salt on the roads which just doesnt help
What type of undercoat should I get it?
(How the underside looks like)
View attachment 97799View attachment 97800View attachment 97801View attachment 97802
Looks good. I always used whatever oil of anything I had available. Amsoil Heavy Duty Metal Protector, Marvel, any brand or type of lubricating oil that was handy when I was working on any vehicle.
I tried Fluid Film, but I thought the nasty smelling Amsoil held up better
There is also a sort of wax compound that can be sprayed on as well as a fogger that comes in a can with a straw made for coating inside frame rails and areas that are hidden you can't access like the inside of rocker panels and whatnot. I would find a place that you can put it on a lift and power wash from underneath and get into the frame and hidden areas to knock out any road grime and dirt that likes to collect and rot out areas before applying.
any way you look at it, you'll be needing to check on things under there and re-apply every so oftin. doesn't matter what product you use, it all can get scraped or wear off. If you find any surface rust, before application, use some evaporust to kill it, then coat it.
The problem I had with Fluidfilm was lack of longevity.
Plain old Marvel Mystery oil out of a squirt bottle seemed to last just as long.
I finally found a guy, not too far away that does the undercoating
I'm thinking about having him do a car we are thinking about buying, if it's still for sale next week. I'm finally heading home Tomorrow. And the 2016 F250.
It's expensive, but what isn't.
The truck needs the larger fuel tank, deleted and the water filter / pre lift pump before it gets coated.
Damn, I need to get the oil changed, cant do it myself due to the injury, now I need to find a decent shop to do it without destroying the motor (ive heard the jiffy lube horror stories) wish I could do it myself. (Tell tale signs for a decent/competent place?)
As for the undercoating stuff, I need to spray the heck out of the underside and THEN add the film fluid/oils?
I heard they can trap in rust, which would speed up the destruction of the vehicle.
Well boys, what do I buy then, ill spray the underneath of it as if its life depends on it (because it does). Otherwise, this is my only option: https://lacnyc.biz/ 😭
That write up about that shop reads pretty good.
If you don't mind us asking about your injury, what happened? hope your okay and heal fast.
as for getting an oil change done. don't know about any of the shops in your area, but do you have any friends or other folks near by that would assist for a nominal fee? you could pickup the oil and filter of your choosing and supervise a new mechanic in training! (neighbor kid who wants to learn)
There is a fellow member here on the forums that lives in NY. He might be close enough for you to meet up and help do wrenching on your rig till you heal up. @DieselAmateur Lives somewhere in NY, and there are a couple of others up there too.
And @Stoney too. He has not been in for a very long time but He too is over there and has some good knowledge on this platform.
I know He was having a lot of problems with his truck and I think He eventually parked it.
He might even have some interchangeable parts.
Stoney and I are about 300 miles north of NYC in the Southern Tier/ Finger Lakes region. I have a mechanic neighbor with some contacts in the NYC area, can see if he has any recommendations. Or the better option is get the heck outta NYC and come out to the country 🙃
