Rarcustoms
- Messages
- 6
- Reaction score
- 19
I recently joined because I picked up an Optimizer engine. It was pulled from a running driving 2008 military HUMVEE with less than 12k miles. It is naturally aspirated and very clean with no oil on the outside at all. The date code is 11 16 P. I’m trying not to tear it down until I am ready to continue on my project next summer, but would like to know if all military 6.5’s are built the same internally. This one does not have the girdle so definitely a 6.5. The questions I have are below:
1) I was told that all the heads, turbo or not have the diamond pre-chambers. I have read the opposite.
2) I have found conflicting information on what turbo (center mount or side mount) will or will not work on the motor with a variety of different parts needed and not needed.
3) which turbo set up is a better way to go? I have or can have as much space for the center mount set as I need. I do assume I’d be tearing down the engine if I go with the center mount.
Long story as to why I don’t have all of the original 599 motor, but the chassis I am putting the motor in is a k3500 standard cab if that helps at all.
