i have a dissembled mid 80s 6.2 ad the camshaft has picked up rust ad is unusable , Question , i have a 6.5 diesel can i use the 6.5 camshaft in y 6.2 ? thanks for the advice thanks
@bubbabilt
That sounds like a rig I would like to see if you get a chance.
As mentioned above yes the cam will work- same cam specs.
There’s a stack of advice about the engine while ya have it apart if interested.
