battery chargers
just a number
Active Member
Trenton ON
My battery charger is on it's last leg. any suggestions on what to look for in a replacement. or should I say what to avoid. It's only going to be used for car/ truck batteries so the 6v setting isn't needed? I need one big enough to have a decent charge time but not take up alot of space. I was thinking something around a 40/15/2/ charge rate.
I got a small one from Sears (Die Hard)
It has Battery Type Selector:
Conventional Low Maintenance
Maintenance Free Deep Cycle
Charge Rate Selector:
2A
10A
50A Engine Start
Here a couple of pics next to a 8 1/2 X 11 paper so you can tell the size.
Cost me right around 140 I think.
I have the big sears one on wheels. Sears actually makes good battery chargers for the money. I have used it for many years to start oil trucks heavy equipment etc. It was under 200$ IIRC
2A
10A
50A Engine Start
got (i think) the same thing, and it works quite well. :thumbsup:
well it bit the dust. sears no longer carries them:mad2:. I was looking a couple from 'schumacher'. a bit more cash but a few extras. any heard good/bad about them. I know their website is a PITA to use:mad2:
so far I found them at TSC, Canadian tire(under NASCAR nameplate) and walmart.
I was looking at 2 different ones, both are wheeled. one is model se2001 and the other is se4022. the first one is cheaper but the second one has a battery+ alternator testers.
I like the Minn Kota chargers for permanent under-hood installation, to keep the batteries topped off while the truck is plugged in. They're not as fast as a big bulk charger, but they'll charge most batteries overnight. I like that you wire them up once and forget them. The chargers seem to last about a decade.
