boost fooler help
ghost183
Brooklyn, NY
hey guys..
i just order a sh*t load of stuff for my truck..
triple gauge pillar pod, gauges, 2 1/4" xover, 3" DP, 4" straight exhaust, no cat/muffler/resinator, marine injectors from pensicola (planning on GL-4 soon enough)
but in the meantime till i get the cash flow up for heath, i figured ide try that 10k pot boost fooler, but im a little confused, i went to radioshack.com and did a search for 10k potentiometer and came back with 6 differant values.. and styles...
http://www.radioshack.com/search/in...k potentiometer&origkw=10k potentiometer&sr=1
which one do i use?
and how exactly do i wire it, i know i cut the green wire and solder the pot inline.. and somewhere in there theres a ground as well.. but where?
271-1715
Search is your friend. Look in the 6.5 Technical library under B for Boost Fooler.
i did, a whole bunch of googlegobble came up.. like 300 threads or something.. but i didnt think of going to the tech section, but thanks jefaire, thanks for the part number
No problem. Searching is largely a matter of practice, learning what to ask the thing to find. That's why I always suggest it, 'cause everyone (including me) needs the practice at choosing search phrases.
There is a circuit diagram and everything you need in the 6.5 technical reference sticky at the top of this forum.
If you need any help. you know where to find me.
